Low Boost issue - what can it be?
Old 12-31-2008, 09:09 AM
EGRoadster's Avatar
Default Low Boost issue - what can it be?
<center><img src="http://www.koshok.net/tt/boost/run.jpg"></center><p>
Solution: turns out the N75 was installed incorrectly.
Hi All,
I have a 2000 225 Coupe Quattro and it only is able to manage 10-11 PSI. Something is not right.
I tried unplugging the MAF.
I tried a spare MAF on hand.
I tried a spare N75.
None helped.
Any ideas?
If anyone wants the CSV file, it is at:<ul><li><a href="http://www.koshok.net/tt/boost/run.csv">http://www.koshok.net/tt/boost/run.csv</a</li></ul>
Old 12-31-2008, 10:01 AM
GeTT da NeTT's Avatar
You need to try the unplugged MAF for at least 100 miles. Could be a bad DV
Old 12-31-2008, 10:04 AM
EGRoadster's Avatar
Default Will try that
DV is new... But could try to change that too.
Other ideas?
Old 12-31-2008, 10:48 AM
Rest In Peace
TTinCT's Avatar
Default assuming it is a 225 as there were no made as a model 2000, they were 2001's>>>
your MAF readings are low, but not terribly so....what does block 32 say?
If it is a 180...then the MAF readings are fine
Old 12-31-2008, 11:36 AM
EGRoadster's Avatar
Default APX motor. This is an EU car. They had 225 in 2000
5.6% and -0.8% for block 32.
Seems there is a Vac leak.
It got a TTDA, Evoheatshield, DV relo and an O.CT flash.
New O2 sensor,
New plugs,
New AIT
New MAF
Cleaned injectors
New fuel filter
Any ideas?
DxC
13
12-28-2005 06:28 PM
lusttre
01-23-2004 10:49 AM
Kampoenk
07-31-2003 04:40 AM
castilian
04-05-2003 11:14 AM
tsltm
14
05-21-2002 12:31 PM
Quick Reply: Low Boost issue - what can it be?
