Check engine light on MAF
Old 02-27-2015, 02:36 PM
njr002's Avatar
Default Check engine light on MAF
I'm new to audi. i got the check engine light on and code said its the Mass Air Flow. what can i do to fix this problem. thank you
Old 03-01-2015, 09:37 AM
Mister Bally's Avatar
Replace the defective part the diagnostics indicated to you. Use standard automotive troubleshooting techniques to verify simple things liek maybe the connector for the MAF is just disconnected/corroded and the sensor may still be good.
Old 03-11-2015, 10:04 AM
njr002's Avatar
[QUOTE=Mister Bally;24661392]Replace the defective part the diagnostics indicated to you. Use standard automotive troubleshooting techniques to verify simple things liek maybe the connector for the MAF is just disconnected/corroded and the sensor may still be good.[/ok, i check the sensor and cleaned it with MAF cleaner and with in 10 check came on again. where can i buy this part whats good website or store i can buy this part. ]
DickieUK
06-05-2007 05:59 PM
silverbacktt
07-08-2004 07:00 AM
gasboddle
11-25-2003 07:07 AM
MattC
09-21-2003 03:18 PM
KiddJoey
06-28-2001 06:26 AM
Quick Reply: Check engine light on MAF
