Mk1 tt 225
Mk1 tt 225
Currently having problems on boost car is fine at half throttle but once the throttle is applied more soon as boost kicks in hard a 2k it seems to judder and pop and bang as if it's hitting a fuel cut! Anybody had this sort of thing happen and would like to share?
Thanks Luke.
Thanks Luke.
are you sure it isn't a random cylinder miss fire? you would see the check engine light on the dash flashing repeatedly like a Christmas light if this is the problem. my 03' TT was giving me this same issue. I knew it was a miss fire, just turned out that the spark plugs I just bought and installed weren't gapped correctly, causing the miss fire.
Ballykid, Are you sure you know what you're talking about? Have you ever repaired your TT out in the 11°F cold on snow covered pavement?
Yes, you have. And on the note you referenced above, you learned a valuable lesson about non-OEM brand spark plugs. Use what the manufacturer says to use.
OP; ballykid is right with what he said above. Does your Check Engine Light illuminate upon start-up? Asking in case someone cut the wire from the Engine ECU to disable it. Even with no CEL, you should run a diagnostic scan using the Ross-Tech VCDS interface & software. Forget the generic hand-held tools. They probably won't help here.
Here's Ballykid the other night away from home at college. The worst kind of "homework".... Ballykid; are your fingers still numb? When you're done with school, I see a heated garage or home in a warm climate in your future......
Wow, looking at the pictures here are making me cold. Where is college for ballykid? When I was in school the great outdoors was my garage too, I was a whole lot younger then and could do that kind of thing. Glad I stuck college out, and like you mention have a heated garage today. Nice work there ;-)
Haha well thank you for the vote of confidence. 21 years old and I call Michigan State University my home away from home. Although, not having a garage, heated or not, up here is a down side, but it all works out as home is about an hour drive away, insulated and heated garage included haha. That's why I called my dad (Mister Bally) up to bring me the tools I needed to finish up the job. Repair was needed due to a snapped bolt on the dog bone mount on the TT, which caused the engine to torque and rotate violently enough to break loose the banjo bolt on the power steering pump. Of course, I lost all the power steering fluid as well when this happened. It was a GREAT time
Jonathon316
New Member Welcome Area
01-14-2018 08:13 PM
MelloYelloS4:Indkted
09-13-2004 12:04 PM
