I keep getting an "engine torque overlimit" DTC/CEL and hitting limp mode.... temps were cool and
Old 07-20-2007, 02:20 AM
LiTTespeed's Avatar
Default I keep getting an "engine torque overlimit" DTC/CEL and hitting limp mode.... temps were cool and
boost machine has not been cranked up - VAG tells me it's "sporadic" - any idea what gives? kind of annoying to lose all power in traffic - one day it could get downright scary if not deadly..... luckily a rolling restart took care of the issue but I like to avoid those wherever possible..... any thoughts?
Old 07-20-2007, 03:17 AM
Scenic Driver's Avatar
Code 17744?
Old 07-20-2007, 03:26 AM
LiTTespeed's Avatar
errrrr...... dunno the # off hand from memory......
Old 07-20-2007, 03:39 AM
Default >>>
From the Bentley if this is the same code:
17743/17744 - Engine torque monitoring Control limit exceeded
Check Mass Air Flow (MAF) sensor
Check coolant temperature sensor
Check Intake Air Temperature (IAT) sensor
Large leak; check hose setup
Old 07-20-2007, 04:06 AM
LiTTespeed's Avatar
thanks - I'll check the ProDiag later but I think mine is different....
Old 07-20-2007, 05:30 AM
Elder Member
kodeTT's Avatar
better have a spare MAF on hand...someone will check it tomorrow.
Old 07-20-2007, 05:42 AM
DerTT's Avatar
Default A couple of options come to mind ...
A bad MAF (as Evan pointed out). This should be easy to test- either disconnect it and see if the car runs fine (a bit rich, but should not go into limp mode if MAF is bad) and/or log a couple of runs to redline in 2nd/3rd with the VAG (block 02/03 or 32/33 if I recall) and check the m/g readings for the MAF.
Or, your cluster is on its way out- that was the issue on mine with the car randomly going limp or shutting off. A bad cluster can give off very wild symptoms ...
Old 07-20-2007, 05:43 AM
SpoiledHeeb's Avatar
Turn down the boost machine a bit...
Old 07-20-2007, 07:33 AM
LiTTespeed's Avatar
I just put a new MAF in the other day and it was fine g/s wise....
Old 07-20-2007, 07:34 AM
LiTTespeed's Avatar
Default it was 75 degrees and low/no humid and I was not onthe boost at the time....
but I can de-tune it as I did a few weeks back but I am nowhere near the limit (although I guess the car is telling me otherwise, eh?)
Quick Reply: I keep getting an "engine torque overlimit" DTC/CEL and hitting limp mode.... temps were cool and
