TT (Mk2) Discussion Discussion forum for the Mk2 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2007-2014
2008 3.6L Air con issue
Old 07-23-2016, 11:33 PM
Patrickthierry's Avatar
Default 2008 3.6L Air con issue
Hi,
I have an issue with the air con.
I went to 2 shops already to check it and everything is fine, and there is nothing to be repaired - changed.
But
The air con stops working when weather is really hot. It seems like there is an automatic security system switching off the AC above 45 - 47 degrees Celsius .
I live in Dubai we reach those temperatures often.
1/ Is my guess of an automatic "security" AC switch off correct?
2/ How can I solve the issue?
My wife loves her car but she can't use it during summer!
Regards.
Patrick
Old 07-24-2016, 05:48 AM
Dhynes's Avatar
Cermastore.com makes a product that when applied, it helps keep the A/C system cooler by allowing better heat transfer while treating the metal internals. I've used the product on my recently sold 2013 Hyundai Veloster Turbo. I never had any issues, just took advantage of it as I was using his other products. Not sure if this applies, but you might be able to change the water pump thermostat to a lower temp point to keep the car cooler. Please, anyone correct me if I'm mistaken.
Old 07-24-2016, 06:13 AM
Hi,
Thanks, that's the point I'm not sure what goes wrong.
Each time outside temp goes above 45 - 47 degrees Celsius the AC stopped and the AC light switch off also.
It happens even on the highway not only in traffic so it looks like outside temperature drives the "automated" security but I'm not sure and I can't get confirmation by local dealer. They test the AC again & again and everything is fine.
Patrick
Old 07-28-2016, 05:19 PM
mlfox's Avatar
Try pressing the "AUTO" button on the climate control and hold it pressed when the A/C shuts off. Report back if that changes things.
Regards,
mlfox
Old 08-06-2016, 11:53 PM
Hi,
Sorry I did not try that. Car was with the dealer again. I got it back for the week end.
Temp sensor in front of the main radiator was replaced.
It seems to be OK for now.
Thanks
Patrick
alcarazj
29
11-17-2021 06:45 PM
Greg5OH
12-18-2016 03:45 PM
chaputski
Audi allroad
12
11-09-2011 08:32 AM
apk-S4
Mid Atlantic Discussion
32
12-11-2007 07:31 AM
ncstteve
11
07-18-2000 03:26 AM
Quick Reply: 2008 3.6L Air con issue
