Temperature of air from vents
The temperature of the air coming in through the vents(in the economy mode)is quit a bit warmer than the outside air.Is this normal,or is my vent system messed up.Any thoughts would be appreciated.
If you figure out how to vent the outside air in, let me know
Steve, I own a roadster and live in the tropics. Yesterday, while driving around between 11AM and about 3PM I had to leave the AC on even with the top down. In econo mode, the heat coming out of the vents seemed a lot hotter than the outside air. In addition, with the AC system turned off, the floor turn into a pancake griddle.
Not plugging but a sunshade...
definitely does help. I have also found my 225 TTR to be worse with this problem than my 180FWD was. I think the sun and turbo (engine heat) get the dash and intake so hot it blows like a blowdryer. Sometimes I'll run the A/C for a bit to cool the system. Good luck! -Pete
