Audi A4 B7 2.0 Tdi Multitronic electrical issues
Hi guys. I hope someone can give me some advice.
I have the above mentioned car. Its a 2007 model. I bought it as a non runner. The car didnt want to start because it had a electrical issue. The previous owner told me that the module for central convenience was soaked in water(under the carpet of the passengers foot well). So i had it replaced and tried to start the car but the immobilizer blocked the car from being started. Then i had the immobilizer bypassed on the ECU as the immobilizer is also built in the cluster which prevented the car to start. Now the car start and drive but doesnt change gears. Its as if it goes into limp mode. Changing gears manually then the car moves good. What i also noticed is that the speedo, rev counter and temp gauge doesnt work.
So i did a scan again and it keep telling me that the "powertrain data bus is defective"
So what i did was i got hold of a lock set(ecu,cluster, ignition,key and door lock) from a scrapyard.
So i had it installed hoping that it will eliminate the powertrain data bus defective problem.
I did a scan after the install and the same problem shows up again "powertrain data bus defective"
So my conclusions is: either there is a module not communicating with the ecu or cluster or there is a wiring problem somewhere.
Any suggestions or advice appreciated.
Thanks in advance
Wednesday,18,January,2017,14:16:49:05981
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 16.8.4.2
Data version: 20161129 DS267.0
Ross-Tech: Home
VIN: WAUZZZ8E17A084848 License Plate: AUDI 04
Mileage: 164980km-102513mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8E17A084848 Mileage: 164980km-102513miles
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BN
Component: A4 Klimaautomat 2833
Coding: 00000
Shop #: WSC 00000
VCID: 6ED576AA2A8058322B-50E6
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 01001
Shop #: WSC 06325
VCID: 3D7781E63766F3AAE2-4AE6
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 02041
Shop #: WSC 06325
VCID: 418FFD164B9E974A86-4AE6
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 901 D HW: 8E0 920 901 D
Component: KOMBI+WFS 4 H14 0110
Revision: 0110 Serial number: 00000000000000
Coding: 0006111
Shop #: WSC 01642 996 08954
VCID: 26454E8A92F0507293-5102
1 Fault Found:
01312 - Powertrain Data Bus
014 - Defective - Intermittent
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0006111
VCID: 26454E8A92F0507293-5120
1 Fault Found:
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
Shop #: WSC 00000
VCID: 6BD37FBE1992AD1A0C-513C
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CH
Component: Komfortgerát T3B 4035
Coding: 00128
Shop #: WSC 06325
VCID: 79FF55F663CE0F8A8E-4AE6
Subsystem 1 - Part No: 8E2959802F
Component: Tőrsteuer.FS BRM 0606
Subsystem 2 - Part No: 8E2959801F
Component: Tőrsteuer.BF BRM 0606
Subsystem 3 - Part No: 8E0959801E
Component: Tőrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tőrsteuer.HR BRM 0606
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 AA
Component: concert II GRO 0004
Coding: 01005
Shop #: WSC 06325
VCID: 66C50E8A0270907253-4AE6
End-------------------------(Elapsed Time: 08:43)--------------------------
Thanks in advance
Ross-Tech: Home
67 69 75 76 77
Coding: 00000
Shop #: WSC 00000
Coding: 01001
Shop #: WSC 06325
Coding: 02041
Shop #: WSC 06325
Coding: 0006111
1 Fault Found:
Coding: 0006111
1 Fault Found:
Coding: 00001
Shop #: WSC 00000
Coding: 00128
Shop #: WSC 06325
Coding: 01005
Shop #: WSC 06325
jonathondaly@btinternet.com
Audi allroad
02-06-2018 11:55 PM
CSCOKid
33
06-24-2008 07:59 PM
esanmiguel
10-10-2007 07:36 PM
JacobB
06-15-2004 05:40 PM
