Requesting Headlight level sensor code interpretation
My 08 A4 is showing the adaptive headlight MIL. The VAG scan shows this.
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000019
Shop #: WSC 06325 000 00000
VCID: 2953927B80EAFB50562
Part No: 8E0 941 329 A
Component: AFS-Modul links H05 0030
Component: AFS-Modul rechtsH05 0030
2 Faults Found:
00496 - Sensor for Vehicle Leveling; Front
010 - Open or Short to Plus - MIL ON
Freeze Frame:
Fault Status: 11101010
Fault Priority: 2
Fault Frequency: 182
Reset counter: 40
Time Indication: 0
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Reset counter: 40
Time Indication: 0
Am I correct to think I need to replace the sensor unit on my drivers side lower control arm? Or is there some other direction I should go? Any insight is appreciated!
Coding: 0000019
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 40
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Reset counter: 40
Time Indication: 0
Slow response but I had this on both my rear left and right side on my old B8.5 a few years back. If you jack it up and and potentially take the tire off you will see the sensor. In both my cases the plastic had snapped and it was just hanging. After replacing it all was good. They aren't cheap though.
Pokechop
05-26-2009 12:11 PM
smcg3
03-16-2009 10:29 AM
1 Bad DJ
09-04-2008 12:55 PM
Tgr_Clw
48
10-19-2007 04:26 PM
RMcQ
10
07-17-2003 07:14 AM
