Vag-Com help with some codes...
Shop pulled these codes for me:
3 Faults Found:
17867 - Exhaust Gas Temp Sensor 2 (G236): Implausible Signal
P1459 - 35-10 - - - Intermittent
17869 - Exhaust Gas Temp Regulation for Bank 1: Implausible Signal
P1461 - 35-00 - -
17539 - Oxygen (Lambda) Sensor: B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
I already went through changing the passenger side EGT a month ago and now its acting up again... what could it be?
3 Faults Found:
P1461 - 35-00 - -
Paging a Vag-Com proffesional... how does the VAG 15 27B Volt Tester Work
I found in the manual that i can test the wiring with the VAG 1527B Volt tester but how does it work? can i use a simple volt meter to do the same or is there more to it?
lscheres
17
10-15-2011 08:52 AM
homer-j-fong
14
04-03-2007 09:31 AM
