Alternator / Battery issues.
I finally got time to look into what is draining the battery in my '94 90Q. I suspected the alternator, after 3 different batteries were tried and all died after a couple days of use. I pulled the alternator, which is a breeze with all of the AC parts removed, then had it tested at Autozone. It came back GOOD after a minute or so running on their tester. The tech seemed to know it would after about 20-30 seconds, because he said "It's gonna pass" and it did.
I got the alternator reinstalled and put in a good, charged battery to test her out again. This time I did an amp draw test but it came back clean, with just .049 amps. I double checked the connections, took her for a few mile test drive and retested with the meter. At this point, I was getting .047, which I figure is well within acceptable range.
So.... with no excessive amp draw, a working battery and a supposedly good alternator, where do I look next? Do I just drive it around for a few days and see if it dies again?
I'm thinking about running some voltmeter leads into the car, from the battery, so I can monitor the meter while driving, since our cars don't have a gauge for that. My thinking is that something is up with the alternator and that way I could see if the battery drops below 13v. Plus, it might help me get the car home before the battery starts to fade too far.
Any info will help. I already STFA and got nothing like my situation, so please don't flame if there is already a post on this. Just point me there and I'll be happy.
Thanks !!
Thanks !!
I think your on the right track
Here's a few things that are simple to do. Even without installing the meter to read while you drive, you could:
- stop the car and meter the battery with the motor running and not. Is it getting charge?
- are all the cable ends electrically clean? Follow the wires that cross under the oil pan too.
- are the alternator brushes worn down shorter and now weakly sprung against the armature?
- what is the highest voltage your battery will keep after being charged the day before off the car?
- What is the voltage on the battery in the car in the morning after sitting overnight after being driven long enough to be fully charged the day before?
- is the ignition switch / trunk wiring / cigarette lighter failed / failing and draining the battery while driving or when the key is out?
further reading on drains:
https://www.audiworld.com/forums/sho...hlight=battery
'81 tic-tac
12
07-15-2022 07:03 PM
Nvncibl
09-18-2012 06:08 PM
I'm No Pro
13
12-15-2006 08:58 AM
