AUGHH! Alternator problems! Please help...
So When I installed my Reman'd alternator my voltage at the battery was:
Running - no headlights/AC: 13.8v
Running with AC: 13.4v
Running with lights: 13.4V
Running with lights/AC: 13.1v
Now it's:
Idle - 12.7v
AC on 12.4
Lights on 12.4
Lights + AC - 12.2-12.3
What's weird is that when I check the voltage at the alternator with the car on it reads like this:
Large post: 13.8v
Small post: 14v
^perfectly normal numbers!
So what could be the problem here? The cable from the alt to the battery? The alternator itself?
help me please...
Now it's:
Idle - 12.7v
AC on 12.4
Lights on 12.4
Large post: 13.8v
Small post: 14v
help me please...
alt post was HOT - 1.66 drop from battery to alt
Battery + to alt + while running = 1.66v
plus the alt post was HOT so theres resistance there - time for a new terminal
No Bozos!
You're on the right track
Go from point to point and figure out where the biggest loss is.
I got burned by that years ago. My TR7 used to have a dead battery constantly. I kept checking the voltage at the battery clamp and it was always ~14v. Then one day I checked at the actual battery post and it was around 11. A quick cleaning of the terminals and all was well.
Think about a new cable as well as terminal.
15 minutes south of Vegas last year I had that cable melt on me at the battery end. If corrosion has traveled up the cable at all, the resistance can generate a LOT of heat. Combine that with a hot day and you can have serious trouble. I'm lucky I didn't have an engine fire.
BINGO! replaced the cable and ends
I replaced the alt to battery cable and converted to a marine battery terminal
Idle - 13.8v
AC on 13.67v
Lights on 13.67v
Lights + AC - 13.5v
^ much better
Thanks everyone
Idle - 13.8v
AC on 13.67v
Lights on 13.67v
Lights + AC - 13.5v
^ much better
Thanks everyone
quattrotto
14
12-21-2002 12:04 PM
