dear moribund exasperated
If you get a chance could you let me know what the tolerance ranges are on the Electronic Coolant Temp Sensor?
(also what book are you getting all this out of? guess i need a copy)
That sounds so formal... ;-)
I got that info from a German A4 repair manual. I haven't checked, but the Bentley should show the same info. It's just hard to find anything on the Bentley CD.
Anyway, I can give you some info. As I said earlier, check resistance between contacts 1 and 3 on the coolant temp sensor:
For every temperature, you should get a specific resistance (+/- a little bit):
Degr. F --> Resistance
32 --> 5.5k Ohm
50 --> 3.7k Ohm
68 --> 2.5k Ohm
86 --> 1.7k Ohm
104 --> 1.2k Ohm
122 --> 950 Ohm
140 --> 600 Ohm
158 --> 425 Ohm
176 --> 325 Ohm
194 --> 250 Ohm
212 --> 200 Ohm
32 --> 5.5k Ohm
50 --> 3.7k Ohm
68 --> 2.5k Ohm
86 --> 1.7k Ohm
104 --> 1.2k Ohm
122 --> 950 Ohm
140 --> 600 Ohm
158 --> 425 Ohm
176 --> 325 Ohm
194 --> 250 Ohm
212 --> 200 Ohm
but attention getting?
My sensor poles are labeled A-B and C-D. At 75 degrees A/B are waaaaaaay out of spec but C/D are pretty close to matching the above numbers at 2.0?.
This is good and bad, good because if C/D are akin to 1/3 then my old sensor is still good and bad because uh, well now, crap, it is probably the wiring?
lmariorod
10-26-2017 11:39 AM
Audi Other Audi RS2 (recreation) for sale
Georgi_Kirov
09-15-2015 11:11 PM
Hawaiiannights
01-16-2001 05:33 PM
TommyS401`
10-25-2000 03:07 PM
