Exhaust Reversion
Exhaust Reversion
I did a little searching and have not found any info on this. Has anyone ever had any experience with this on their 12V?
I'm currently building my 12V and looking to get some ideas. I have been doing quite a bit of work to the heads, intake manifold, and exhuast manifolds to improve flow, but was concerned with "gasket matching" the exhuast ports as it may cause some exhuast reversion.
Has anyone gasket matched the exhuast maniolds to the heads and what were the effects- positive, negative?
Thanks
Thanks
well you wouldnt want the gasket sticking into the ports. Thats turbulence and restriction. Defeating all what you did. just match the gasket to the ported head. Let me know if doing that stuff helps. Im going to rip into my 12v soon for a refresh.
The concern here would be if both ports were exactly matched -(the head to the exhaust manifold)the exhaust gases may momentarily flow backwards during the overlap phase of the camshaft at low cycling rates, i.e. reversion, simply stated. However, a preventative method to overcome this problem is to match the exhuast manifold to the exact size of the gasket and leave the exhuast ports on the heads slightly smaller, 1/16" all the way around. This step makes it difficult for the exhuast gasses to move backwards. I've read through the head workshop and saw no mention of this. I wasn't sure if it was something to consider or if everyone has just been gasket matching with no issues. There seems to be quite a few here who have done work to the intake side, but no mention of the exhuast side.
Pre95
24
09-12-2008 12:44 PM
audikillsbmw
15
02-21-2008 02:51 AM
|skolnick
Audi Original "S" Cars
11-20-2007 08:29 PM
|skolnick
09-01-2007 08:59 AM
