Help me find best vacuum line to feed seafoam through to get to the most cylinders...
As well as a description of where to locate it? or pics for a 2.8 12V if you got any.
Also, how is this procedure any different from removing the throttle body and the egr and cleaning them out??
thanks in advance!
thanks in advance!
I'd use the brake booster hose that is attached to the intake manifold
You don't even have to use Seafoam. Water works, too. ;-)
Removing the TB and cleaning it is all good and I recommend it, but it won't clean your intake manifold or piston tops.
Why do you feel you have to resort to fairly drastic measures like Seafoam (or water decarbonization)? Do you have a carbon buildup problem? If so, why? How will you prevent this from happening again?
4Rings::G2 boosted::
01-15-2004 07:34 AM
Audi juice
10-11-2001 07:30 AM
