It LIVES! New A4 project fired up today.
Patient: recently acquired 1996 A4 12V fwd manual trans.
I replaced what seemed like a sluggish starter with a cheap used one...still no go. The starter smoked a few times as I was testing, so I figure it's a decent $50 investment.
I bit the bullet and pulled the front end off to pull timing belt covers, get access to the serp tensioner and crank bolt, and get room to work on it. I pulled the serp belt and found the AC compressor seized. It fired right up and sounded fairly good.
Next thing on the list is to find the coolant leak the PO reported. I filled the reservoir and let it run for about 5 minutes without seeing any leakage. I guess it can't be THAT bad of a leak...unless it ends up being a head gasket.
What are my options on the compressor? Is this going to require a whole new compressor or could it be a faulty clutch that's somehow keeping the pulley from turning?
The AC compressor "may" have been the cause of coolant leak (overflow)...
due to the load a seized compressor placed on the engine causing it to overheat. The AC clutch "may" have gotten VERY hard to turn prior to fully seizing.
I cant belive it, you got a steal on that one..and only the compressor?
wow, i wish i was so lucky, you should come to vegas, and maybe you can dump a brand new Audi in the garage this time
Congrats
Congrats
Is there any way to mechanically disable the seized clutch so I can at least drive the thing until
I get the compressor sorted out? Looks like its the early Zexel brand compressor based on the VIN.
S4AVNT
9
07-21-2008 12:14 PM
Fuzzbeaner
Audi 100 / A6 (C4 Platform)
06-08-2005 05:44 PM
