Is this piston damaged? Pics inside
There is a small dimple on the very egde of the piston in cylinder one. I do not know if this dimple was already there or was caused by the bent valves. I did not see any immediate damage to the bottom of the valve. I would think to make a dimple this significant, there would be damage to the valve. Hopfully, the piston if fine and I can just replace the valves. I did not clean the piston or the walls. I just wiped it out with a paper napkin. The piston walls are smooth and shiney. There ws some oil in the cylinder. About a teaspoon worth. I think this was due to the bent vales and/or valve seals. Any info is appreciated.
How to post pics...
This forum is old, so no [IMG] tags. You need to use HTML to post multiple pics. Google "html img tag".
<img src="http://i5.photobucket.com/albums/y190/cis8vgti/PHOT0227.jpg">
<img src="http://i5.photobucket.com/albums/y190/cis8vgti/PHOT0226.jpg">
<img src="http://i5.photobucket.com/albums/y190/cis8vgti/PHOT0228.jpg">
Or go to "reader tips" under forums, AudiWorld resources...
You can use a single picture or HTML links in your signature. Here is the required HTML format:<ul><li><a href="https://www.audiworld.com/forum/faq.shtml#9">Scroll up about an inch to see the HTML code for posting pics and links.</a></li></ul>
wizardofoddd
23
05-19-2019 07:15 PM
ScottAW
08-06-2002 07:02 AM
ed@4induktion.com
11-30-2001 01:28 PM
channelv
02-24-2001 08:34 AM
