Plenum Porting
Old Aug 4, 2004 | 09:38 PM
Slye A4's Avatar
Junior Member
Default Plenum Porting
I had recently gone to a dyno machine and got it dynoed. 1996 12v Q after getting the results I along with the Mechanic running the dyno where puzzled by the results the hp drops in mid run then returns! If I can get the pic to work, take a look. The Audi mechanic in MN said that it is the plenum porting as it opens and closes during mid run.
Old Aug 4, 2004 | 09:41 PM
moribundman's Avatar
Default The plenum does what?
Are you sure he didn't say the variable intake manifold switched from the longer intake path to the shorter one at higher RPM?
Old Aug 4, 2004 | 09:42 PM
Slye A4's Avatar
Junior Member
Default Re: The plenum does what?
check the (picture post) by search forums
Old Aug 4, 2004 | 09:45 PM
What do you want me to look for?
Old Aug 4, 2004 | 09:46 PM
Slye A4's Avatar
Junior Member
Anyway I wanted to know if someone has ported their plenum and has any pics and hp/FT-lbs results. Thanks
Old Aug 4, 2004 | 09:48 PM
nothing's Avatar
Default Yes, that is your variable intake manifold switchover, which happens around 4000 rpm.
<center><img src="http://pictureposter.audiworld.com/79119/dyno_run2.jpg"></center><p>
Seems like there is something wrong with your engine at 5500 rpm, however. Or is that what the AFC power curve is like? My AAH pulls hard all the way to the limiter.
Old Aug 4, 2004 | 09:49 PM
Default The plenum is plastic. What's there to port? Just remove the thing!
Replace it with a silicone hose kit that puts away with the whole plenum for improved flow. Check the Abnormally Aspirated site linked in the right top corner of the forum for a hose kit.
Old Aug 4, 2004 | 09:50 PM
nothing's Avatar
Default It's called an intake manifold.
The plenum has nothing to do with what you are talking about, it is made of plastic and cannot be ported - it can be replaced however. The intake manifold CAN be ported - STFA.
 Michael S. Palmer
Old Aug 4, 2004 | 09:51 PM
Default Oh, the pic in your picture poster!
Just link it, so that we don't have to look for it. :-P
Old Aug 4, 2004 | 09:52 PM
Slye A4's Avatar
Junior Member
Default Re: Oh, the pic in your picture poster!
I'm a nOOB! Sorry
