Weird idle problems..
Old Mar 20, 2006 | 07:11 PM
bluenote's Avatar
Default Weird idle problems..
I'm having weird idle problems. Up and down, and sometimes it dies. Aside from the ICV and replacing the ECT sensor, what could it be? What should I clean? I've been searching the list and it looks like maybe replace my O2 sensors? clean the throttle plate? Seafoam?
Comments??
Old Mar 20, 2006 | 09:09 PM
moribundman's Avatar
vacuum leak(s), spark plug wires, spark plugs...
Old Mar 20, 2006 | 10:04 PM
bluenote's Avatar
Default this is probably going to sound dumb.. but how do i find vacuum leaks??
Can i just replace hoses??
Old Mar 20, 2006 | 11:46 PM
Default If you haven't replaced the vacuum hoses during the past 4 years or so...
chances are you got some leaky ones. It's a good idea to prophylactically replace all thin vacuum lines every few years. Vacuum hoses that are closer to hot spots go bad the quickest.
Vacuum leaks are not only due to leaky hoses, but also due to leaky gaskets, for example the plenum-to-throttle body gasket, or due to cracked valve cover breather hoses. Sometimes a vacuum hose pops off and goes unnoticed (plenum to TB!).
Sometimes you can hear a bad vacuum leak. Spraying carb cleaner around a leaky gasket (with the engine running) will result in a change in idle and thus identify a leak. Really bad vacuum leaks can trigger a "lean condition" code.
I'd start with replacing all vacuum lines (people seem to like BMW vac hose best as replacement) and a thorough visual inspection.
A loping idle can also be due to compound issues. Vacuum leaks, a dirty or defective ICV, bad spark plugs wires or spark plugs, and even a less then pristine MAF sensor can contribute to poor idle.
SJGQ5
Q5/SQ5 MKI (8R) Discussion
Aug 11, 2022 06:51 AM
bballfreak
9
Apr 14, 2019 06:59 PM
Junius
Aug 11, 2016 06:48 AM
changareth
Sep 25, 2015 11:27 AM
camcanada
Q7 MK 1 Discussion
Sep 24, 2015 05:58 AM
