Whats the torque on the camchaft sprockets supposed to be?
LOL... sheesh guys, if ya don't know look it up or defer to someone that does...
this is a VERY "mission-critical" bolt and not one ya want to come loose or let go at/near redline. The results are engine-fatal. Fortunately for him his question was already answered correctly at another forum.
"best guesses, beliefs/opinions and other unqualified answers" should NEVER be proffered on a question like this. Some day someone will take it as the gospel-truth and I doubt the person answering will accept responsibility/culpability for the answer they offered by buying this member a new engine if he uses the advice given.
If ya don't know then the best you can do for this person is say NOTHING!
Ya I know he shouldn't take my word for it, but I was going to look it up later tonight, and post
<center><img src="http://pictureposter.audiworld.com/123501/tbelt.jpg"></center><p>
the picture I have of the timing belt change I did. Since it says in the diagram.
And it might have helped him to find the answer if he spelt camshaft right. Im not sure it if was just a mistake this time or if he does spell it like that all the time.
Actually that book is wrong on factory spec. Bentley has the correct procedure...
but this particular bolt has plagued me for years so I use my own home-brew method which I won't even mention here out of fear it would meet with disasterous results if someone else tried it.
The book that was taken from is likely one of the early Haynes/Chilton repair manuals.
The Bentley spec is as follows:
This is a true "stretch-bolt" so a new (not re-used) bolt must be used and tightened to 22ft lbs then an additional 1/2 turn (180 degrees).
Sir Shnike
07-10-2006 04:48 AM
a62.7t4ceo
03-21-2005 01:18 PM
RainOrSnowS4in
14
02-28-2003 12:30 PM
Type44Q
02-05-2003 05:23 PM
