2011 q5 2.0T engine coolant sensor location
Old 10-09-2016, 07:24 AM
q5dave's Avatar
Default 2011 q5 2.0T engine coolant sensor location
I've searched a lot can't find anything showing the location of this coolant temperature sensor. any help appreciated.
Old 10-11-2016, 06:14 PM
q5dave's Avatar
no one has a digram showing where the coolant temp sensor is located on the 2.0t motor??
Old 10-17-2016, 03:44 PM
Kjack's Avatar
It's in the coolant flange on the back of the engine. Do a Google search for "Audi 2.0 coolant flange DIY" and you should be able to find pics. It's in a tight spot but replacing the sensor and its o-ring should be pretty easy. Replacing the whole coolant flange assembly is a bit more involved though.
Old 08-30-2020, 09:01 AM
macgy's Avatar
Default Coolant temperature sensor location
My brother 2012 Q5 air conditioner suddenly blowing hot air and the temperature gadge went up and down, forum members pointed out that the coolant temperature sensor need replacement & they are right!, took me a while to locate the sensor which according to several forum member it is at the back of the engine, wrong!
Facing the front engine, the sensor is on the right, to locate it is easy as the 2 coolant hose from the radiator connect to the water pump, which is where the sensor is located.
The coolant temperature sensor is behind the manifold which has been removed
For easier removal, turn the sensor to the position as shown in the picture b4 removing the clip holding the sensor & make sure to replace with a new O ring. Cheers.
abrittis (08-03-2021)
sswss
2.0T FSI Discussion
11-09-2010 10:06 AM
corne
12v V6 Discussion
07-09-2010 12:22 AM
A. Shea
Audi allroad
03-18-2008 06:37 PM
89type44
01-21-2006 05:50 AM
red90q
01-11-2005 03:07 PM
Quick Reply: 2011 q5 2.0T engine coolant sensor location
