No start b5 s4
No start b5 s4
i had an issue where i drove my 2000 audi s4 b5 parked it and 4 hours later went to start and it would not start just cranking and cranking i put a code reader on and pulled 2 codes p1392 and p1338 they are camshaft sensors replaced both and cleared codes tried starting and both codes came back with no starting just crank I’ve seen some posts about this but no definitive answers on what to do can anyone help !?
Not sure if this will work but my 2000 A8 went completely dead when I left the battery disconnected too long. Thought I would have to get towed to dealer. Found a fix. Remove the instrument cluster from the dash. Only a couple of screws just above steering wheel. Disconnect the cluster from behind. Wait five minutes and reconnect it. It was one of the most satisfying DIY's ever for me! Everything lit back up and the car turned over and started. It sounds like yours is in the first stage of a lockout mode so I don't know if it will work but it won't hurt. My theory is that It sort of re-establishes the electronic hand shake between vital components and the cpu. In fact I don't think that you can do it with newer Audis due to a discovered potential for theft.
Try a search for removing the instrument cluster and you'll see how easy it is.
Hi again Nick. Search this group for "Dead Instrument Cluster" or just click to see all my posts because Audiworld is the forum I found the answer on an prior to the three posts I've written to you, I had only written to thank the guys that posted the immobilizer fix. One of those guys even posted a .pdf on cluster removal.
Good Luck!
Good Luck!
