Rotor size
Rotor size
Hey, I need to get some new brake pads, and the ones that I saw mentioned that they had to be 312mm....but, I have a 2000 Audi A6 2.7t Quattro...does anyone know what size rotors I have? Front and Rear are different size rotors....thanks!
Re: Rotor size
My 2000 2.7T has 321mm front rotors. this can easily be confused with 312mm. The 321mm rotors have 2 piston caliphers. The pad set has 4 pads per calipher for a total of 8. Most vendors don't have pads for these, so if you're ordering from a catalog make sure you see a picture showing 8 pieces. Also, resurface or replace the rotors or the new pads will squeal like a banshee when they warm up.
Rickee Rajput
A4 (B8 Platform) Discussion
10-06-2016 09:46 AM
