RS4 vs bosch 42lbs injectors
arent the heads of the injectors different yielding different spray patterns?
leading to some low rpm misses?
or is this more related to the upgraded size of the maf?
can you elaborate?
Differnt?
as i understand it, its ~5 degrees more nawrow.
but, woth High horsepower k04 cars, at 4 bar, your ~78% duty cycle. vrs. 90-100% ( static <90% )
on the rs4 @ 4 bar.
you can always go with higher FPR.
on the rs4 @ 4 bar.
OldManTan
Mid Atlantic Discussion
02-11-2007 05:10 PM
Why did we not choose to use RS4 components with our fueling kit? While the RS4 turbos are quite cap
STG3S4
89
09-29-2006 06:01 PM
hadokenny
04-18-2006 04:51 AM
What is the ideal flow rate for an injector for Stage 3 at 4 Bar? Is the RS4 ideal, or close enough?
PhiS4
88
02-27-2006 09:22 PM
Imolavirus@BuehnEngineering
12-05-2003 05:46 AM
