slight tapping from driver's side cam it seems
I have just done Timing Belt four weeks ago, and it seemed there was ever since a slight noise coming out of that side.
It's true I didn't use a cam lock bar, but I made good marks.
I have been driving the car on the freeway up to 100MPH without problem or weird noises.
What do you guys think it is? Can it possibly be the timing belt alignment? Or it is a cam adjuster issue?
Thanks.
Thanks.
Re: slight tapping from driver's side cam it seems
It doesnt matter how good your marks were, you NEED the lock bar. If the timing happends to be good then check the tensioner in the bacl of the head and make sure its not bad.
Chris - German Auto Repair
I use 5W40. I must say it sounds better now that I've opened it
and messed w/ the timing belt a second time
I cannot explain what I changed. I moved belt one tooth on each cam sprocket and then moved right back.
somehow it got better
Just finished my timing belt and replaced all the gaskets. The front driver side engine(2.8 30v) has
Shan H
06-02-2008 03:00 AM
Shan H
05-27-2008 07:04 PM
audikillsbmw
07-28-2007 10:46 PM
Jewelp
04-25-2003 12:53 PM
