Turbo oil return line o-ring replacement...
Dealer says my turbo oil return line o-rings are leaking on both sides (04 with automatic, 60K miles). Anyone have instructions for replacing the o-rings? Didn't find anything through a search.
might want to email the poster of the linked threads for answers
<a href="https://forums.audiworld.com/s4/msgs/2185705.phtml">Mike 2ks4</a>
<a href="https://forums.audiworld.com/s4/msgs/2732376.phtml">The Jerbel</a>
Tools for O-ring replacement
If you are talking about the O-rings leaking where the oil return lines hookup to the oil pan, then I suggest using a set of stubby allen wrenches, or maybe a hex bit with some small wratchet. When I replaced one of the O-rings, there wasn't much room, so the stubby allen wrenches (from Orchard supply hardware here in Calif) really helped. I think I also had to unfasten the centermost sway bar links and let it rotate down for a little more room. There might be a write-up on this, but that is what I remember when I worked on my car. - Jim (Calif_Kid)
iKhmaiFoSho
2.0T FSI Discussion
03-31-2016 12:05 PM
rakta *chchchanges
03-26-2009 03:34 PM
S4_Cinci (I S'edTFA)
01-10-2002 07:10 PM
