Turbo Rebuild? Any Cons?
What are the Cons of rebuilding a turbo? I found a few kist ranging from 40.00-100.00. is there anyway to get a replacement impeller or other things you might need? Links to anything you know about would be very helpful.
Thanks, JJ
Thanks, JJ
Re: wouldn't be surprised if there wasn't a rebuilder in Charlotte.
Defintely not something you want to tackle yourself. You need to balance the spine to some pretty tight tolerances. I had my A4 K03 rebuilt by a turbo shop in CO Springs in 2004. Turbo had 120k on it and the wastegate flap was completely thrashed, leaking boost. Cost $200 at the time but was still running strong when I sold the car in May 08 with 160k miles. Well worth doing IMHO. Hit your local yellow pages and look for truck (as in Semi truck) turbo rebuilders. There are a ton of turbo diesels out there and shop I found works exclusively on turbos.
