Oil pressure sending unit
Old Feb 26, 2010 | 11:01 AM
mekyjesy's Avatar
Default Oil pressure sending unit
Hello,
I have a '03 A6 Quattro with the 3.0 engine, auto tranny, 118k miles. Recently it has been intermittently displaying a low oil pressure warning on the dash. I am going to start with replacing the oil pressure sending unit, I ordered one and it should be here in a few days. Where exactly is this sending unit located? Is it easy to get to and change?
Thank you for your help
Old Feb 28, 2010 | 02:22 PM
rs4tech's Avatar
the oil pressure switch is located above the oil cooler where the oil filter goes...its a little trickey to get to...there is a tsb on the oil pressure lights coming on on those engines, more than likely you have a massive oil leak at your adjusters or the oil check valves are bad in your block
Old Mar 2, 2010 | 04:02 AM
mekyjesy's Avatar
Default link to tech bulletin
Is there a link to this tech bulletin? Where can I find more info on this situation? What adjusters are you referring too? How in depth is this?
Old Mar 2, 2010 | 05:54 PM
rs4tech's Avatar
the adjusters i am talking about are the cam adjusters, the check valves live under the valley pan under the intake...either job is very involved....
mike just for fun
1.8T Discussion
Apr 17, 2014 12:57 PM
Margus
12v V6 Discussion
Feb 26, 2009 09:49 PM
SNogaro4
May 14, 2006 07:24 PM
psmith
30v V6 Discussion
Apr 17, 2006 06:37 PM
audirunner
Mar 28, 2004 08:56 AM
