ECU
ECU
Here is the problem. I have a 87 4000 that 2Bennett has done a V8 conversion on for me. The 4.2 V8 is out of a 97 A8. Having come out of a car with a automatic an into one with a manual shift the OBD is throwing a transmission speed code. So dose anyone know where I might find an ECU for a 97 4.2 with a manual tranny?
Thanks, Marshall
Thanks, Marshall
Re: What is the code?
I just went into the shop today and Andrew said that he will get me the code number. It's an engine speed code that is being thrown because there is no pick up at the transmission.
Re: It has to be a transmission speed sensor code.
You are right I think it is a transmission speed sensor code. I will be back in the shop tomorrow and ask them what the code number is.
Re: sounds like a beast of a car ... lets see some pics!!
I will take some pictures when I run the car at Laguna Seca later this month. Audi Club Driver event all welcome. Feb 18-20 check out the Golden Gate chapter of the Audi Club.
That is the wheel speed sensor located by the driver's side output flange.
This is an automatic tranny, but the stick shift has it on the same location. Is your speedometer works?
<img src="http://pictureposter.audiworld.com/80919/5hp24a.jpg">
Re: That is the wheel speed sensor located by the driver's side output flange.
I went to the shop the other day and had a talk with Andrew. He said that they will try and get a signal from the back of the speedo. He did not know if it's looking for a sign wave or a pulse.
