Vibrating V8
Old 05-24-2006, 01:09 PM
YannickF's Avatar
Default Vibrating V8
HI
I have an ABH 4.2L V8 in my Audi 100 and the engine often hesitate (with vibrations) to accelerate between 1000 and 2000 rpm (approx)
Some times, the acceleration is perfect.
I have tried to disconnect some sensor (O2, knock sensors, MAF, Idle valve etc...) but the problem persists.
It seems to be better with the O2 sensor disconnected but I'm not really sure.
I have changed injectors and fuel pressure regulator (I have a seconde engine for parts) without any success.
Air Filter (a cleanable) and Spark plugs are new ones.
I've changed timing belt a few weeks ago..
What do you thing of my problem ?
Thanks
Old 05-25-2006, 04:42 PM
MP4.2+6.0's Avatar
Look for vacuum leak in the hoses as a guess
Old 05-27-2006, 11:03 PM
YannickF's Avatar
Default Re: Look for vacuum leak in the hoses as a guess
Hi
thanks for your answer but which hoses are you talking about ?
Old 05-30-2006, 08:27 PM
Senior Member
meatwad/beefcake's Avatar
Default ignition problem
caps, rotors, wires, etc....
Old 06-05-2006, 09:01 PM
brittcrowell's Avatar
Default My A8 4.2 intake vacume leak pics....
<ul><li><a href="http://www.brittcrowell.com/2006/2006-02-08_Working_on_the_A8/">http://www.brittcrowell.com/2006/2006-02-08_Working_on_the_A8/</a</li></ul>
RKsilver
11-11-2014 07:29 AM
Reno_V8
06-07-2009 12:10 PM
motorsport4k
01-18-2009 09:21 AM
bluevr6
Audi Original "S" Cars
03-20-2006 11:13 AM
elmsfordracewayinc
19
03-09-2006 11:49 AM
Quick Reply: Vibrating V8
