2014 A4 keyless entry antenna location
Hey can anyone tell me where to locate the antenna. Cant use the keyless entry or start/stop button. Code reads as an open to antenna.
I found this. It seems there may be 3 locations. In the console, in the drivers door, & in the rear bumper. I am missing having a Bentley manual to refer to. Have you checked the battery in the keyfobs?
https://parts.audiusa.com/p/Audi_201...8K0907247.html
https://parts.audiusa.com/a/Audi_201...S/1348190.html
It is three antennae: center console (interior), driver's side rear door (left), and rear bumper (rear).
If it's the DTC:
Then it could be the circuitry in the J393. Known common issue. I picked up a used unit on eBay and had the dealership install and code it to deal with the immobilizer and component protection issues (ie, you swap it yourself, your car isn't going to start anymore until the programming work is done). Google search on "audi tsb 2021363/5".
If it's the DTC:
Code:
03283 - Antenna for Access & Start Authorization; Left 007 - Short to Ground
If it's the DTC:
If it's the DTC:
Code:
There is no antenna for the keyless operations in the driver's door. There is a sensor in the four door handles, but simply to detect pressure on the two contact points. A defective sensor will not impact the keyless operations except at that door handle. A defective antenna will block all keyless operations. You said the DTC text referred to antenna, not sensor.
SupraTL
28
07-26-2006 03:39 AM
dachtor
10-20-2003 04:30 PM
xxsnsxx
04-04-2001 06:18 PM
