2017 Allroad Drive Select
I'm sure I notice a difference with the dampers from Comfort to Dynamic drive select modes... Is it mean or are they adjusted automatically? If this is the case why can't I change the setting in Individual drive select mode?
type 8K A4 allroad had only adaptive suspension, under PR code 1BP.
type 8W A4 allroad has two different suspensions, 1BP is now passive and the adaptive is now 2MN.
type 8W adaptive dampers now have the wiring come out of the top of the damper, thus why the upper strut mount is different for passive vs adaptive suspension codes.
Note the last pic - https://www.benzeenautoparts.com/use...ut-left/461252
I notice the OP is in Canada. I feel like I read somewhere that the Canadian market allroad do not have adaptive dampers standard the way the US market cars do. That would explain why you don’t have the option to adjust damping in individual mode in drive select. The difference between comfort and dynamic is very noticeable if you do have the adaptive dampers.
vegasS4
10-07-2005 10:55 AM
