Calibrate Steering Wheel Angle Sensor on B9 cars
Does anyone know the procedure to calibrate the Steering Wheel Angle Sensor on a B9 car? All the instructions online appear to be for previous generation cars. I have VCDS.
If you don't have Active Steering, then it can be done using VCDS. I did it myself in the first week of ownership of a brand new car (yikes). if you have Active Steering then I have no idea what's involved and I would suggest getting this done via a dealer.
Infact I would suggest getting this done at the dealer in any case.
[QUOTE:bruce_miranda;25507522] Se non si dispone di Active Steering, allora può essere fatto utilizzando VCDS. L'ho fatto io stesso nella prima settimana di proprietà di un'auto nuova di zecca (yikes). se si dispone di Active Steering allora non ho idea di cosa è coinvolto e vorrei suggerire di ottenere questo fatto tramite un rivenditore.
In realtà suggerirei di farlo al rivenditore in ogni caso. [/QUOTE]
excuse me how do i know if my car has active steering?
also my problem is that I wanted to install the button for the lane assist but now I can't do the calibration both with the old ring and with the new one.
sorry for my english but i use translator
thank you
thank you
can you describe briefly how was done?
VCDS instructions/procedure is accurate?
I think I have a little missalignment to 0º, didn't change anything, just to reset to exact position
But what VCDS does when you activate its basic setting? just marks current position as 0º ? asks for driving? doing anything?
Please, some more information
PS: I have a standard A4 B9 steering assist
I don't drive, so it can't have needed me to drive the car. And when I handed the car back to my wife it was error free. Complete with a new ALA and Heated Steering wheel.
But I did it so long ago, I have no idea now what I did. There were no instructions available then. I am sure there will be some proper instructions somewhere by now.
I also had to do in a 8P many time ago, and I remember I had to drive with steering turned to one side, the other, etc.. following some instructions and took several tries to get calibrated, and now I was affraid of losing steering assitant and other systems by trying without information
maybe current VCDS will provide the instructions..
sounds to you login code was required? I try basic setting and is not sucessful, try the code provided for previous generation
