ECU Tune from IE - proceed with caution
#11
#12
Slippage is when the RPM rises faster than the speed while experiencing no torque.
Like for example a DCT transmission
I don't think this is the case, namely that at 3000 RPM this is when there is maximum torque.
If you start from 1000-1500 RPM what happens? the same thing ?
#13
In your video I don't see the problem.
#14
#15
Update from my side: I posted a video and log screen shot in the IE Customer Group on FB. Someone else chimed in that had the same problem, even after the UNI TCU tune. I tagged the IE folks in the thread, but Tyler and Cristian have both ghosted me since I asked if it was clutch slip. Pretty disappointing to get no acknowledgement on the issue. I've usually had good customer service experience with them.
#16
You didn't mention it but I am assuming when this "slip" event happens you feel the car drop power, or is the log the only way you notice this? When it does this do you have traction control on or off? With as fast as it happens it could be tire slip depending on how repeatable it is. If you slip a traditional manual clutch it doesn't just start to grab again while it is slipping and you keep giving it power. The DSG clutch pack would be similar, if it was really slipping from a physical threshold staying on the power wouldn't make it suddenly grab. To me if it is slipping it's due to clamping force lacking due to the tune taking the engine performance outside the specs of the trans programming with regards to speed of spool and power curves.
Goned (03-21-2023)
#17
So someone with a TCU tune that increases clamping force had the same issue you had without it? When you hit peak torque from a different set of variables it doesn't happen. Seems to be more complex than just a torque limited clutch pack design, after all if the clutch packs have a hard limit then they don't care how you get there. The only thing that could be affected by how fast you arrive at peak torque would be the computer responding by raising the clamping force too slowly. This should be handled by the TCU tune but sounds like it did not for the other person. No idea why they are saying a TCU tune isn't needed, everyone runs around claiming you can't even go Stg1 on a manual without completely replacing the clutch, but somehow the ever more complex DSG should just be fine?
When the slip happens, you can feel it. It results in a staggered acceleration feeling. It doesn't matter if ESC/Traction is off and it happens in 4th gear at highway speeds. No way is this car breaking traction at that speed.
#18
From my understanding, there is no proof that Unitronic increases clutch pressure. I don't think I've seen them confirm that and the product page for their TCU tune does not specifically mention that (if so, please correct me!). I know TVS offers that, but the drivability is sacrificed as a result.
Look at your logs, the one where you claim you have slower build to torque and no "slip" you actually peak at a HIGHER final torque number. Certainly the RPMs are lower which factors in some but there's so much that just seems to not say traditional slip but something else going on. This is where you have to rely on your tuner and send them logs and have them pour over data. If this is a common issue they must have seen it in testing and have at least some ideas. If they've never seen it and the issue is not widespread they would need to look into it.
Given the OP came here just to post this thread and has not posted here for 2 months it seems likely they either solved their problem and as always did not update the community or gave up and equally did not update. If you end up continuing to diagnosis this I hope you keep us updated.
#20
Finally got a response from IE acknowledging the clutch slip....
"We have only seen this Behaviour on very few cars. and it has happened over time. It is clutch slip but a very mild slip that should be sorted with the upcoming updates for the platform."
