radio default setting
Trying to get radio to default to the pre-set position instead of the last station that was listened to. My B-8 alllroad did this but can't get the 2018 B 9 to do this. Any ideas?
1 Post
As far as I know, it always goes back to the station you were listening to. I have one of the preset buttons set to my default station and use that to switch to radio instead, and it works perfectly.
Yes, it will default to the last station listened too, prior to being turned off. The issue is, it will default to band selection, (i.e. sirius, FM AM ) and not the pre-set selection settings.
1 Post
I might not have explained what I meant properly.
On mine, it definitely changes both the band/source and the frequency, when I press a preset. For example, present #1 = 91.3 FM, Preset 2 = channel 99 XM. Pressing these two buttons changes between FM and XM correctly.
So, pressing preset #1 at any point both drops me into radio and chooses the radio station; because I only really listen to one radio station 90% of the time, that preset button becomes my 'switch to radio' button.
And I may have not expressed my frustration well, When the engine is turned off, the radio will default to the last station (band) that was listened to. If I was listening preset #2 on my pre-set list say sirius 80's, when I start the car back up the 80's station is still playing but I must go back to my presets and push the left hand push switch to call up the band selection mode to change the band selection back to presets as it has defaulted to the sirius band, not remained on the preset band, as my 2015 allroad did.
thanks for your patience.
Let us know if you figure it out.
I may have misunderstood your request, but have you used the radio switch that is right in front of the gear selector? If you press up on your RADIO button above the gear selector, four times, it will cycle through the four options (AM, FM, XM and PRESETS). Then you can use the volume **** next to the gear selector and slide left or right to change easily between the preset stations.
As I said your way makes it easier as I don't have to click down on the left switch and the turn the joy *** around till I get to presets and then select. I can now just use the radio selection switch. Thanks
