"ln 2" indicator? how to turn it off
Well, it CAN mean that you need service, but it depends on the actual mileage of the car..
How many miles do you have now?
And, as for turning off the light, they may or may not charge you, depending on how close you are with the garage.
This indicator comes on at a certain mileage interval.
It is not telling you that there is something wrong with the car, rather that you have gone a certain number of miles since it was last reset. READ THE MANUAL to find out more about this.
Of course the dealer can reset this, but they may charge you for this if that's all you are having them do. If you are having them perform your routine service, they will reset this indicator for free.
Depending on the model year of your car, you can either use the VAG-COM tool by Ross-Tech to reset this indicator, or you can follow a manual procedure which can be found in the tech section of AW. In '96, the indicator must be reset using the VAG-COM tool or by the dealer.
