* Bought the Neuspeed front/rear sway for my FWD 98 standard.. What setting to use for adjust rear ?
Correct. The FWD version is thicker. Never heard of the FWD version cracking the subframe........
but nonetheless I'd still recommend the soft setting for everyday driving.
That's what I have my Lltek 20 mm bar set on, and I wouldn't want it to be stiffer.
My Neuspeed rear bar is 28mm and set in the middle position on both sides.
I believe the only rear bar they make for the FWD is the 28mm, and you don't have to worry about the subframe problem. Problem is on quattro only. It really helped reduce understeer, couldn't believe the difference it made!!! Car handles so much better. Middle position is suppose to give you a medium effect on roll resistance & increas roll stiffness by 50% according to a chart I got from NS.
notoriouS4
09-14-2005 12:37 AM
kutscha
02-03-2004 11:59 AM
Phil
Performance and Tuning
11-28-2001 10:29 AM
