`00 1.8tq Rear Brakes, @23k mi..looks more worn than front...
Old Oct 23, 2000 | 12:55 PM
TommyS401`'s Avatar
Junior Member
Default `00 1.8tq Rear Brakes, @23k mi..looks more worn than front...
I was visually inspecting the rear brake pads w/o removing my rear wheel and noticed that they are really thin. The front brakes are like 4.5x as thick as my rear brakes. Did the front and the back start at the same size? I would think that the front would wear before the back twice before I have to change the rear. Comments? Oh yeah, rear wheels are normally cleaner than the front. that would suggest that the front should be wearing more than the rear.
Old Oct 23, 2000 | 03:45 PM
Stang Guy's Avatar
Member
Default Normally fronts go out b4 rears (more)......
so you may like to check that your parking brake is not binding, thus holding the calipers against the rotor and wearing the pads prematurely. I'm assuming you have yet to replace the front pads, right? If you have not yet replaced the front pads and the rear pads are worn, it would suggest a problem with the calipers binding. You can check the movement by removing the wheel and then releasing the parking brake - the wheel should be stuck with the brake on and free with the brake off. If the calipers are binding you will not be able to turn the wheel when it is off the ground, even when the brake is released.
Old Oct 23, 2000 | 04:30 PM
RKA's Avatar
RKA
AudiWorld Uber User
Default If the calipers were binding, he would already have warped rotors...
On some cars (not sure about the A4), it is perfectly normal to see the rears wear first. You are correct, the front brakes do most of the braking, but other factors (pad thickness, pad material, and surface area of the pad) will affect the wear rate of the brake pads.
On my last car, the rear brakes would need to be replaced twice as often as the fronts (pad's were thinner, smaller, and used a softer material).
Old Oct 24, 2000 | 04:59 PM
Stang Guy's Avatar
Member
Valid point - assuming no mechanical problems then it's time to replace them due to normal wear
Pope
May 23, 2011 01:31 AM
Moe
11
Feb 18, 2006 02:49 PM
technics100
Mar 16, 2005 12:14 PM
englsh
Jun 21, 2004 12:14 PM
dvandentop
Apr 24, 2003 10:39 AM
