1 Fault Found: 17545
Anyone have any idea why I'm getting this one fault. I turn off the check engine light and it takes about 3 days to return.
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 35-00 - -
P1137 - 35-00 - -
you can check the tech section or B5 FAQ. Really you need to get MAF
cleaner from your local auto parts store and then take the MAF out to clean it. If you have a K&N air filter I would remove it and go back to stock paper filter.
Are you referring to this stuff??
I had that code once, right before the T-Body and
control unit die.<ul><li><a href="http://www.crcindustries.com/auto/content/prod_detail.aspx?S=Y&PN=05110">Linky click here</a></li></ul>
Corey
12-08-2006 10:00 AM
xdriver
11-03-2006 07:54 AM
