12V - removing plug wires - what do you pull on?
'96 12V A4
I've had bad experiences with other cars and separating the boot from the wire on removal, but I don't see any other way to get them out without some special tool to get below that metal hat and allow you to pull that up.
Am I missing something, or do I just give them a yank?
Thanks
Thanks
1 Post
'96 12V A4
Thanks
Thanks
Well, I tried the yank technique and no go. Not a one. So I made this tool to grip them better.
It worked well for 4 of them, but partially tore the boot on one, and then mangled the boot on another. Once I'd mangled the second boot, I took the wire out and grabbed the inside of the porcelain insulator with a pair of long nosed vice-grips. Still couldn't remove it. I clamped a second pair of vice-grips on the first - perpendicular to them and with a stiff yank it came off with pop. These were obviously never lubed.
The next day I was looking at the stainless steel part and noticed that there seemed to be a some distinctive design elements to it that may indicate a "special VAG tool" was missing from my equation. Sure enough, there is a tool specifically designed to grab under these ears on the shield
Here it is from ZDMack.
http://www.zdmak.com/wbstore/main.as...CTMP=1&LowCt=0
Those wires must have been on for a long time. Sorry to tell you to yank on the ribbed rubber, but in the future they probably won't be so hard to take off.
This job seems:
A) Difficult ----> Check for a special tool
B) Moderately Easy ----> Check for a special tool
C) Simple ----> Check for a special tool
No problem here. That technique worked for you and sounded reasonable since there is a distinct ribbed area. FWIW - the Bentley manual doesn't list that tool either - or even a procedure on how to remove them. I'm quickly realizing that the decision tree for this car always begins.
This job seems:
This job seems:
Your tool is impressive! That put a big smile on my face.
:: www.ECStuning.com :: Now with EXTENDED Customer Service hours!! | FIND US ON FACEBOOK!!
Phone: 1.800.924.5172 - Sales: 8:30am to MIDNIGHT EST | Customer Service 8:30am - 8pm EST
Questions? PM us for a quick response! | Email: Pete@ecstuning.com
You think that's a tool. This is what I resorted to during a timing belt job. I'd made a set of "special tools" when I did timing belt on Porsche 944 so I figured this would be ...cough... on par with that. I was wrong as I was flabbergasted to find there are no keys in the timing gears. Anyhow, this is what I came up with. I had to buy the crank isolator as that was beyond me.
