17748
Old Oct 14, 2021 | 05:16 PM
Frostbite's Avatar
Default 17748
So I can't figure it out. I replaced the timing belt. Made sure it was TDC with a 1/4 inch extension, replaced the cam position sensor and crank position sensor, put on a new cam chain and tensioner. Marks on cams lined up with TDC and arrows on cam caps with 16 rollers in between cams. The car has an APR stage 1 tune. The only thing I can think of is that the intake cam was missing one cover and all the cam cap bolts were over torqued. So maybe the end of the intake cam where the sensor is was put on wrong?! Also there is plenty of oil in the head so it can't be a restricted oil pump, at least IMO. Any ideas?
Old Oct 18, 2021 | 10:00 PM
Cybersombosis's Avatar
Have you double checked the marks on the crank pulley cover and valve cover? Nothing mentioned about that in your post. Just your 1/4 inch extension.
Old Oct 21, 2021 | 10:23 AM
The Stig's Avatar
X2 Double check the timing alignment
Old Oct 21, 2021 | 04:56 PM
4Driver4's Avatar
Tech Guru
Tech Guru
What cam mark did you use to set the belt timing? What crank mark?
Csims225
Apr 20, 2021 11:11 AM
Newbie123
Jan 30, 2018 08:46 AM
xspiritdannyx
12
Feb 3, 2016 07:52 AM
a62.7t4ceo
Feb 23, 2005 11:14 AM
jasaab
Feb 9, 2004 04:30 AM
