is 18x8.5 rims too wide for the a4?
Not ideal...8" is perfect...but there are people running 8.5"...
I used to have rims that were 8.5" and the rims stuck out farther then the tires. You can always run a wider tire, but then be prepared for some fender scraping.
I'm running 8.5 w/ no problem. just lowered it 1.5 inches without an rubbing issues
<img src="http://pictureposter.audiworld.com/21836/18_5.jpg">
<img src="http://pictureposter.audiworld.com/21836/18_4.jpg">
Stilauto SR300 18 x 8.5 225/40/r18
i'm running 18x8.5 also right now, car is lowered a little over 2 inches with koni COs
I only rub under hard cornering, or any other maneuver that requires full suspension travel. Doesnt happen that much. I'll be rolling my fenders soon.
Re: is 18x8.5 rims too wide for the A4?
18x8.5 is fine as long as the offset is 32 - 35mm. You can pretty much put 18x10 if you wanted to with a 36mm offset...offset is always key when fitting any rim.
Check w/ www.AutobahnX.com - they have tons of wheel info.
Lewayhun
09-26-2014 04:43 PM
Felk_2.7T
07-02-2005 06:25 AM
bcacly
10-01-2002 11:37 AM
Spam-n-Rice ETR
07-16-2001 01:20 PM
