1996 A4 2.8L EGR Valve issues.
Also I have The CarMD ODBII Devise, which gave me the code that directed me to clean my EGR system. It threw Me a different Code then you provided "moloveshisaudi1254". But I'm not sure if it was just the use of a different devise which threw the different code. My code that came up was "P0401" (P, Zero, Four, Zero, One)
I would Love to show you the pictures that I took. I'm sure that They would really Help. But I don't yet know how to post Pictures In with a message post(I haven't tried). Any tips on that would be great. I'm sure I probably Just have to go to "go advanced" Instead of "post quick reply" So I'll try that tomorrow. If you don't see the pictures up by tomorrow night, Then I didn't figure it out.
Stay Cool Folks... I mean You do drive an Audi...Don't you
16785 (P0401) Exhaust Gas Recirculation Flow Insufficient Detected
INTERMITTENT
As far as posting pictures, you have to upload them to another website like photo bucket. There are lots of them that will let you do it for free so just search on google. Once the pictures are uploaded you can link to them in your post. That's the way I do it, if you want more specific instructions PM me. Also you can probably check out the Wiki and find some info there.
-Good luck, looking forward to those pictures. Mo.
I think some people just squirt some gunk in there and call it good.
Of course if you do that it doesn't stay fixed very long.
There are Secondary Air Injection/Kombi Valves (sometimes listed as EGR valves but not always). There are two of them one for each bank and they are different from each other.
They are fairly high failure and expensive but easy to replace. As far as I know there is no cleaning procedure for the EGR passage on the 30 valve V6.
Easier than the 12 valve as you don't have all the solenoids on top of the throttle body, Idle control valve and the EGR passage.
Make sure all the vacuum ports on the throttle body and plenum are clean also.They tend to get blocked and cause weird idle problems.
Worse thing that could happen is it doesn't help. So you have wasted $5 and an hour or two.
You could probably get a used throttle body at a junk yard. The VW Passat uses the same one as does the A6.
Here's one
http://cgi.ebay.com/ebaymotors/THROT...Q5fAccessories
They are different for Auto/ 5 speed. I think you can either one on the 5 speed, but the auto can only use the correct one.
