1996 A4 2.8L EGR Valve issues.
Worse thing that could happen is it doesn't help. So you have wasted $5 and an hour or two.
You could probably get a used throttle body at a junk yard. The VW Passat uses the same one as does the A6.
Here's one
http://cgi.ebay.com/ebaymotors/THROT...Q5fAccessories
They are different for Auto/ 5 speed. I think you can either one on the 5 speed, but the auto can only use the correct one.
All of the removed crud will fall out at the EGR end.\
A thinnish wire should make it all the way through, but it does make a 90 degree turn at the throttle body.
If a lot of black crud comes out you are good.
Stay Cool Folks... I mean You do drive an Audi...Don't you
http://www.ibdguy.com/posting.shtml
upload pics to photo manager site (ie: photobucket)
where ever you decide to store your pictures, there should be a image link code.
copy that, paste in the forum text with code decribed in the above link.,
add the copied file name within the (" ")
make sure the image size is *abouts 500-800 height-width.
i know, i'm posting computer-how-to in a automotive-how-to. hope this helpful.
