1997 A4 12V6 Throttle Q:
Either the linkage is binding or rusting up and the pedal doesn't return with the throttle cable attached.
When the engine is started it increases speed until the motor is stopped.
How does one get under the intake tubing to get at and free the throttle cam and butterflies in the throttle body in is 12V 2.8?
Is there a way to do it without removing the intake tubes?
Any other tips or TSB (tech service bulletins) info?
hope this helps...
here's a link to a tech article onhow to remove/replace the throttle body.<ul><li><a href="https://www.audiworld.com/tech/eng13.shtml">link</a></li></ul>
it's not that hard to get to it.. follow some of the writeup for cleaning the ICV...
might be easiest to remove the whole TB, so you can be CERTAIN that it's not the problem. Don't forget also, there is a linkage and mechanical stuff for cruise control too..
Re: hope this helps...http://www.audiworld.com/tech/eng13.shtml
Link and Kris' comment helps too.
I can tinker with the Cruise rod from the vacuum diaphragm, that's accessible.
NICE!
-Scott by BOSTON
NICE!
-Scott by BOSTON
Pre95
12-30-2008 05:55 PM
--OOOO--Audifox
12v V6 Discussion
10-28-2008 09:20 AM
forced induxion
03-13-2006 01:28 PM
pleiades
10
11-12-2001 10:24 AM
