2000 A4 1.8T - codes
Old May 29, 2011 | 04:19 AM
vtraudt's Avatar
Default 2000 A4 1.8T - codes
I pulled the following codes, engine code ATW.
After erasing the codes, some still showed up. Went directly into the respective modules and erased again.
Which are likely to reappear?
Which need to be tackled?
Is the engine code effecting driveability, fuel consumption, performance, etc.?
VCDS Version: Release 10.6.4
Data version: 20110418
Saturday,28,May,2011,10:48:26:22662
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 058-906-018-ATW.lbl
Part No: 4B0 906 018 P
Component: 1.8L R4/5VT G01 0008
Coding: 07201
Shop #: WSC 65535
VCID: 2E5DFA65C087
2 Faults Found:
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 35-10 - - - Intermittent
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Shop #: BB 24334
VCID: 1C3920ADA63B
No fault code found.
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D57
Coding: 00140
Shop #: WSC 06335
VCID: 2D5FFD69CD81
1 Fault Found:
00787 - Temperature Sensor in Fresh Air intake duct (G89)
30-00 - Open or Short to Plus
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 K
Component: Airbag Front+Seite 1002
Coding: 00104
Shop #: WSC 06335
VCID: 3E7DCA2510E7
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 980 C
Component: B5-KOMBIINSTR. VDO D11
Coding: 00242
Shop #: WSC 00000
VCID: 2B5BF371F395
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump D11
Coding: 16140
Shop #: WSC 06335
VCID: 4081B4DD6A13
10 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01365 - Lock/Unlock Switch; Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06335
VCID: E0C1D45D4AD3
1 Fault Found:
01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
35-00 - -
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 8D0 035 195 A
Component: Radio D00
Coding: 00205
Shop #: WSC 06335
VCID: 2449184D9E4B
1 Fault Found:
00856 - Radio Antenna
36-10 - Open Circuit - Intermittent
End ---------------------------------------------------------------------
viktor88
VAG-COM Discussion
Nov 7, 2010 04:13 PM
q2quest
VAG-COM Discussion
Feb 12, 2010 01:11 PM
duhki22
Nov 19, 2007 08:01 AM
S4MarkS4
VAG-COM Discussion
Nov 10, 2006 03:49 PM
Dr.Duct_Mossburg
13
Mar 10, 2006 11:28 AM
