2001 AWM GIAC Chip or Flash?
Basically wondering if what was installed ilnes up with the car (I understand a K03s with GIAC SW should be about on par with a ko4 and basic SW), maybe the PO never know better...he seemed to think the car woke up though...said there was the tune only, no "options" to select different programs (stock vs more boost).
Car feels slow to me - I'm coming from much faster cars (and don't expect this to win races), but had a neighbor with a 2004 GLI ride along and he didn't "feel" the chip either. Car pulls ok in 5th on the highway, but doesn't feel fast at all rowing through the gears.
Just curious - I'm about the replace the coolant temp sensor which might help (reading varies a bit below middle)- already has the 710 DV...
But earlier APR chips were soldered. Not sure about GIAC - but both are flash now. How to tell if you are flashed? Not sure...maybe go to an authorized independent shop who sells GIAC and see if the can check.
As far as upgrades to the turbo / SW - you should likely inspect to see what you have. The 2001 model has a different turbo than the pre 2001 models. K03S (sport) as oppossed to the K03. 2001 is DBW with VVT. If your turbo was upgraded to a K04/other - who knows if they also had a custom tune, upgraded injectors, fuel pump, etc....Yes, most say that the 2001 with VVT and K03S does not require an upgrade to a bigger turbo and all of the other stuff. Pre-2001s would have benefitted more from this kind of move. (Although there is the APR Stage 3 kit)
Sounds like you need to do some investigation to see what you have. As suggested maybe put a boost gauge in, or look at getting Ross-Tech Vag-Com software/cable to get some stats.
Revo also makes chip fash for the 2001 AWM (I have it)
BTW, you said you're coming from faster cars...like what? The GIAC program only puts you somewhere around 220hp so if you're coming off something with 300hp+ of course your A4 is going to seem slow. Believe me, if you drove the car when it was bone stock you'd be DYING for that GIAC program.
