225/50 vs 205/55 - Kris Hansen?
#22
I miss the real feel you get from struts... you can tell what's happening all the time..
As for wider being less stable, I'm not sure I understand how that would be possible? The only negative handling trait of wider tires I've ever encountered is the tendency to tram line more..
#23
Elliptical contact patch varies wider or more narrow. More narrow = more directional stability.
Maybe this expresses itself most obviously in tramlining. Other wide tire effects include: hydroplaning, steering feel, unsprung mass, rotating mass...blah blah. Anyway, increased deflection effort off-center steering is not desirable and should not be mistaken for "stability". Check out info on contact patch if you want.
Question: If I want to get 225 size tires for my OEM 15 inch wheels, what does the ration need to be
poopeter-el sigthief
08-01-2002 11:51 AM
Beng
Wheels & Tires Discussion
01-09-2001 07:55 PM
