'96 2.8 Keyless Remote- Programming Procedure?
Old Oct 28, 1999 | 12:35 PM
Joe A
Guest
Posts: n/a
Default '96 2.8 Keyless Remote- Programming Procedure?
I checked the FAQ for programming keyless remotes. It states the '96 models may require a different procedure. Does anyone know this procedure? Any help is greatly appreciated.
Old Oct 28, 1999 | 01:05 PM
RajR
Guest
Posts: n/a
Default Get the dealer to do it...(more)
And I don't think any additional functionality (as shown for 97 and up models) can be programmed for the 96 A4.
Old Oct 29, 1999 | 05:22 PM
Antone
Guest
Posts: n/a
Default Re: It's easy, if you're just adding a new fob
Assuming you're just adding a new fob for a car that already had the keyless entry feature.
You'll need two keys.
1) Open the driver door, turn the ignition switch to on, but do not start the car.
2) Close and lock the dirver door with the other key.
3) Hold down both buttons on the fob for about 5 seconds. The lights should flash and the alarm horn should honk.
4) Open the door, remove the key from the ignition. Close and lock the door with the key.
Your remote should now work.
hardflip15
Apr 18, 2007 11:44 AM
ihaveanaudilikeyou
Sep 11, 2006 01:09 AM
gussfm
Jul 25, 2004 12:23 PM
emerged
Aug 15, 2003 06:15 AM
Dale Kirstein
Aug 27, 1999 10:09 PM
