A4 Engine Rough Idle Question/Problem
Old Feb 16, 2002 | 04:53 PM
EMANIC's Avatar
New Member
Default A4 Engine Rough Idle Question/Problem
I have an A4 2001 2.8Q stock purchased 12/01 and love it, but have a possible problem.
Since about the early spring of 2002, I've had a fairly rough idle. The car sometimes clearly has its 'heart' skip a beat and I feel the rough up and down in the RPMs in the peddle. Now, some people might not notice the roughness, but I do. I have a Honda Oddyssey (for the kids) with a V6 that purrs like a kitten and has absolutely no roghness. The comparison is not flattering to my A4.
(To my mind, with the hood open, the engine also sounds like it has a noticable tap (like what would be considered a valve tap in an old car) but I gather this is fairly common in modern cars/Audis given fuel injection.)
The roughness mostly or completely goes away if I manually increase the RPMs by a few hundred with the foot pedal.
Unfortunately, the problem is fairly intermittant and the two times I brought it to the dealer it was very minimal. It does seem to be worse in the cool/warm weather and better in colder weather.
I am concerned the valves may not have seated properly during break in (but this is based on my recollection of 60s and 70s cars!)
Any idea what might be wrong and/or to look for so I can be knowledgable in talking with the dealer? Am I just a hyper-critical car lover?
You be the judge.
Many thanks!
Old Feb 17, 2002 | 03:44 PM
Stephen Kormilo's Avatar
Default Re: A4 Engine Rough Idle Question/Problem
For whatever reason, the Audi 2.8 V6 seems to idle a little roughly. My 98.5 does, as does my son's 2001.
Old Feb 17, 2002 | 06:07 PM
Perpetual Novice's Avatar
Default Engine should be silky smooth, except for a little ticking from the lifters.
What kind of gas are you putting in and where do you live? You might try switching gasolines for a tank or two.
Old Feb 18, 2002 | 02:21 PM
EMANIC's Avatar
New Member
Default Re: Engine should be silky smooth, except for a little ticking from the lifters.
That's what I would think on the smoothness (and that is how I would describe my Honda Ody V6). I was just starting to think maybe it could be the gas because it is somewhat intermittant.
I live in Northern Virginia and always use premium, though I have no preference between major brands like Exxon, Mobil, Shell and Texaco. I never use places like Gas King, etc.
Also, it has seemed to me before that the roughness gets worse late in the tank. I thought I once read that octane levels go down as the gas is used, although this seems a little counterintuitive.
Hmmm. Maybe I'll pick one brand of gas and stick with that for a few weeks, then shift to another to test the difference, etc.
Any other ideas on why it wouldn't be smooth? Could it be a badly seated valve? Would a compression test tell me something like that?
Old Feb 18, 2002 | 07:38 PM
Bill In SoCal's Avatar
Member
Default A compression test would be easy to do and would give you a good idea. however...
if you are getting rough at the bottom of the tamk you may be sucking sediment from the bottom of your tank.
quattro4ks
Inline-5 Discussion
Sep 15, 2010 04:08 PM
transformer57
Jul 18, 2005 07:57 PM
gotd77
Nov 19, 2002 04:47 AM
stinky
Mar 6, 2002 01:21 PM
kws
Performance and Tuning
Mar 1, 2001 06:45 AM
