Performance and Tuning Discussion forum for various performance tuning techniques and questions
idle problem
Old Feb 28, 2001 | 10:23 AM
kws's Avatar
kws
New Member
Default idle problem
I have a '96 A4 that will idle at 8-900 rpm, then suddenly decrease to about 200 rpm. Sometimes it drops so low that the engine will stall. Any suggestions on what could cause this problem, and can I fix the problem without going to a dealer or mechanic?
Old Feb 28, 2001 | 10:32 AM
unA4dable's Avatar
New Member
A dirty Idle Stabilization Valve is often the culprit, check the archives.
Old Feb 28, 2001 | 10:41 AM
kws's Avatar
kws
New Member
thanks much!
Old Feb 28, 2001 | 05:59 PM
Leszek's Avatar
Default This is a known problem for which a technical bulletin exists!
Give this Technical bulletin to your mechanic:<ul><li><a href="http://tech.vw.com/audipdf/a240001.pdf">Engine, Fluctuating Idle or Idle Speed Too Low</a></li></ul>
Old Mar 1, 2001 | 06:45 AM
unA4dable's Avatar
New Member
This TSB isn't for a '96 A4.
canonicalman
Jan 4, 2006 03:27 PM
gotd77
Nov 19, 2002 04:47 AM
kws
Feb 28, 2001 04:26 PM
sohail
Sep 24, 1999 05:38 PM
